Dynamic Feature Layer Symbology
6265
11
12-08-2010 03:21 AM
RadmilPopovic
My map consist of polygons where each polygon has many attributes. In ArcMap I can show attributes??? values by symbolizing layers  using Categories/Quantities/Field/Classification tools in Layer Property. Changing classifications I change the map geometry.
My question is how to achieve the same functionality in Flex application so that the user on the client side changing the  number of classes or break values can change the map. Still more,  f.e moving slider which represents  nominal values of one attribute from Xmin to X max.
I still use ArcGis 9.3.1 and as I understood, ArcGis Server  9.3.1 couldn???t do it since REST API  is stateless and symbology from map service isn???t used. Does ArcGis Server 10 support dynamic symbology?
Any idea/example how to make Flex appl. where user can explore/change the map by changing value of one layer???s attribute ???
ab1
I'm not the author so... 😛
AnthonyGiles
Honored Contributor
Yes sorry, it's also a discussion thread not a question and answer thread, so I'm wrong on so any levels,
Regards
Anthony
