DrawTool Bug...?
753
06-12-2010 02:55 PM
RobertScheitlin__GISP
I have run into an issue using the 2.0 API update 3 that I think is a BUG or just my lack of understanding.
    So here is the scenario. Using the DrawTool and ensuring that the map has the useHandCursor set to true. The LINE, FREEHAND_POLYLINE, FREEHAND_POLYGON, and EXTENT all return the mouse cursor to the hand once you finish drawing and the DrawTool is deactivated. The MAPPOINT, MULTIPOINT, POLYLINE and POLYGON all do not restore the hand cursor once the DrawTool is deactivated.
Here is the DrawToolSample from the sample page with the one little change of having the useHandCursor set to true on the map, that demonstrates this issue.
<?xml version="1.0" encoding="utf-8"?>
<s:Application xmlns:fx="http://ns.adobe.com/mxml/2009"
      xmlns:s="library://ns.adobe.com/flex/spark"
      xmlns:mx="library://ns.adobe.com/flex/mx"
      xmlns:esri="http://www.esri.com/2008/ags"
      pageTitle="Basic usage of DrawTool">
 <s:layout>
  <s:VerticalLayout paddingBottom="5"/>
 </s:layout>
 <fx:Style>
  @namespace mx "library://ns.adobe.com/flex/mx";
  mx|ToolTip
   font-size: 14;
 </fx:Style>
 <fx:Script>
  <![CDATA[
   import spark.events.IndexChangeEvent;
   protected function bb_changeHandler(event:IndexChangeEvent):void
    if (event.newIndex == -1)
     drawTool.deactivate();
    else
     switch (bb.dataProvider.getItemAt(event.newIndex))
      case "Point":
       drawTool.activate(DrawTool.MAPPOINT);
       break;
      case "Multipoint":
       drawTool.activate(DrawTool.MULTIPOINT);
       break;
      case "Single Line":
       drawTool.activate(DrawTool.LINE);
       break;
      case "Polyline":
       drawTool.activate(DrawTool.POLYLINE);
       break;
      case "FreeHand Polyline":
       drawTool.activate(DrawTool.FREEHAND_POLYLINE);
       break;
      case "Polygon":
       drawTool.activate(DrawTool.POLYGON);
       break;
      case "Freehand Polygon":
       drawTool.activate(DrawTool.FREEHAND_POLYGON);
       break;
      case "Rectangle":
       drawTool.activate(DrawTool.EXTENT);
       break;
 </fx:Script>
 <fx:Declarations>
  <!-- Symbol for all point shapes -->
  <esri:SimpleMarkerSymbol id="sms"
         color="0x00FF00"
         size="12"
         style="square"/>
  <!-- Symbol for all line shapes -->
  <esri:SimpleLineSymbol id="sls"
          color="0x00FF00"
          width="3"/>
  <!-- Symbol for all polygon shapes -->
  <esri:SimpleFillSymbol id="sfs"
          color="0xFFFFFF"
          style="diagonalcross">
   <esri:outline>
    <esri:SimpleLineSymbol color="0x00FF00" width="2"/>
   </esri:outline>
  </esri:SimpleFillSymbol>
  <esri:DrawTool id="drawTool"
        fillSymbol="{sfs}"
        graphicsLayer="{myGraphicsLayer}"
        lineSymbol="{sls}"
        map="{myMap}"
        markerSymbol="{sms}"/>
 </fx:Declarations>
 <s:controlBarLayout>
  <s:HorizontalLayout horizontalAlign="center"
       paddingBottom="7"
       paddingTop="7"/>
 </s:controlBarLayout>
 <s:controlBarContent>
  <s:ButtonBar id="bb" change="bb_changeHandler(event)">
   <s:ArrayList>
    <fx:String>Point</fx:String>
    <fx:String>Multipoint</fx:String>
    <fx:String>Single Line</fx:String>
    <fx:String>Polyline</fx:String>
    <fx:String>FreeHand Polyline</fx:String>
    <fx:String>Polygon</fx:String>
    <fx:String>Freehand Polygon</fx:String>
    <fx:String>Rectangle</fx:String>
   </s:ArrayList>
  </s:ButtonBar>
 </s:controlBarContent>
 <esri:Map id="myMap" level="3" useHandCursor="true">
  <esri:ArcGISTiledMapServiceLayer url="http://server.arcgisonline.com/ArcGIS/rest/services/World_Imagery/MapServer"/>
  <esri:GraphicsLayer id="myGraphicsLayer"/>
 </esri:Map>
 <s:Label text="The DrawTool can be used to draw new features which can then either be used as input for another task or saved as new features in a feature service (using the FeatureLayer.applyEdits)" width="100%"/>
</s:Application>
BjornSvensson
Esri Alum
That's a bug (that we didn't know about).  We'll try and fix it before the 2.0 release.
Thank you 🙂
