drawinginfo.renderer.symbol.source...
2448
07-01-2010 02:11 PM
RoyceSimpson
At beta, update 3, I was doing with success...
item.legendImage = o.drawingInfo.renderer.symbol.source;
to get the image source url string for point features.
Now the "source" property returns a ByteArray and crashes the app.
I was using the string to populate a custom Item object as show above. Then using the item in a List object for a custom legend/TOC.
How can I do the same thing now with a ByteArray?  I notice that what used to be a url with PNG file is now like this:
"http://hiatus/ArcGIS/rest/services/dev/EM_Assets/MapServer/32/images/C8D05CC1"
Anyway, I'd just like to be able to use the drawinginfo property (or whatever property would have the image path for point features) for the point symbol.
Thanks much.
RoyceSimpson
Here is more verbose code snippet for what I was doing successfully at beta update3...
   protected function titlewindow1_creationCompleteHandler(event:FlexEvent):void
    emLayerList.selectedIndices = selectedIndices;
    emAssetLayer.getAllDetails(new AsyncResponder(onResult, onFault));
   private function onResult(allDetailsResult:AllDetails, token:Object = null):void
    _emLayerDetails=allDetailsResult.layersDetails;
    _emLayerListDataProvider = new ArrayCollection;
    for each (var o:Object in _emLayerDetails)
     var item:Item = new Item;
     item.layerID = o.id;
     item.name = o.name;
      if (o.geometryType == "esriGeometryPoint")
     _emLayerListDataProvider.addItem(item);
DasaPaddock
You could call http://help.arcgis.com/en/webapi/flex/apiref/com/esri/ags/symbols/Symbol.html#createSwatch() or pass the ByteArray to the Flex Image component as it's source.
RoyceSimpson
Thanks Dasa,
I've got the ByteArray working... what would be an example usage of the createSwatch method?  How would I use the resulting object as the source from an Image?
DasaPaddock
You can just add the UIComponent returned by createSwatch() to a container to view a representation of the symbol.
