Does the SFV 2.0 has to reside at root
956
08-01-2010 05:18 PM
HaroldBostic
I want to setup folder structure where the content for the SFV 2.0 does not reside at root.  I can use the config file change the paths for most of the content however, I still get
Error #2036: Load Never Completed. URL: http://localhost:3094/widgets/WidgetContainer/WidgetContainerWidget.swf
I guess I could change this and recompile by using the development version, but I wanted to see how far I could get without doing that.  Does anybody know if the path for this Widget can be set via the config file?
DasaPaddock
The Viewer can be placed as-is under a subdirectory under root. The url's are relative to index.swf.
Yes, you can add a url attribute to the widgetcontainer. See line 406 of ConfigManager.as.
