does REST API support se_gemoetry layer for time enabled dynamic service?
2081
06-11-2012 12:23 PM
HongTang
Hi, ESRI:
I am currently working on a time enabled project to display points on map.
I don't have SDE. So, I turned on se_gemoetry for my Oracle database and create a view for the map displaying purpose.
Then, I use dynamic map layer to display the time enabled information on the map. But I could not get anything showing. However, if i export the se_gemoetry enabled view to file GDB feature class and publish it to map service. Everything works well.
I wonder if REST API supports se_geomety layer for time enabled functionality? Thanks. Also, is there any particular steps I need to do to make it work?
Sabrina.
