Disable feature layer log in prompt?
1046
08-10-2012 11:54 AM
IanKramer
Hi, can anybody tell me how to disable the Log In pop-up in the FlexViewer 3.0 version?  It's the one that pops up for secure feature layers.  I customized my viewer code to obtain a token from the query string and assign it to all my services, but I still get the log in prompt.  I don't want to use this in my app.  I haven't been able to locate it in the source code anywhere.
Thanks!
Ian
IanKramer
Dasa, thanks for the info!  It helped me find the solution.  I just had to disable the IdentifyManager in the ViewerContainer.  Here was the function.
private function initializeHandler(event:FlexEvent):void
                IdentityManager.instance.enabled = false;
DasaPaddock
Are you using the Edit widget? If yes, see this thread:
http://forums.arcgis.com/threads/63034-Edit-widget-token?p=219615#post219615
IanKramer
