Disable browser scrolling when using map.
3494
11
11-30-2010 11:32 AM
JasonLevine
Hello All,
If you've ever embedded a flex map into a browser, you've probably noticed that when you use the scroll wheel to zoom in or out, you also scroll the browser window as well. I was looking for a way to disable the browser window scrolling when you're over the map when I found MouseWheelTrap. Basically, you copy the following class package into your project, and then call for it in your main.mxml:
package com.esri.ags.script
 import flash.display.Stage;
 import flash.errors.IllegalOperationError;
 import flash.events.Event;
 import flash.events.MouseEvent;
 import flash.external.ExternalInterface;
  * MouseWheelTrap - stops simultaneous browser/Flash mousewheel scrolling
  * @author Liam O'Donnell
  * @version 1.0
  * @usage Simply call the static method MouseWheelTrap.setup(stage);
  * @see http://www.spikything.com/blog/?s=mousewheeltrap for info/updates
  * This software is released under the MIT License <http://www.opensource.org/licenses/mit-license.php>
  * © 2009 spikything.com
 public class MouseWheelTrap
  static private const JAVASCRIPT :String = "var browserScrolling;function allowBrowserScroll(value){browserScrolling=value;}function handle(delta){if(!browserScrolling){return false;}return true;}function wheel(event){var delta=0;if(!event){event=window.event;}if(event.wheelDelta){delta=event.wheelDelta/120;if(window.opera){delta=-delta;}}else if(event.detail){delta=-event.detail/3;}if(delta){handle(delta);}if(!browserScrolling){if(event.preventDefault){event.preventDefault();}event.returnValue=false;}}if(window.addEventListener){window.addEventListener('DOMMouseScroll',wheel,false);}window.onmousewheel=document.onmousewheel=wheel;allowBrowserScroll(true);";
  static private const JS_METHOD :String = "allowBrowserScroll";
  static private var _browserScrollEnabled :Boolean = true;
  static private var _mouseWheelTrapped :Boolean = false;
  private const INSTANTIATION_ERROR :String = "Don't instantiate com.spikything.utils.MouseWheelTrap directly. Just call MouseWheelTrap.setup(stage);";
  public function MouseWheelTrap()
   throw new IllegalOperationError(INSTANTIATION_ERROR);
  /// Sets up the Flash and the browser to deal with turning browser scrolling on/off as the mouse cursor enters and leaves the stage (a valid reference to stage is required)
  static public function setup(stage:Stage):void
   stage.addEventListener(MouseEvent.MOUSE_MOVE, function(e:* = null):void { allowBrowserScroll(false); } );
   stage.addEventListener(Event.MOUSE_LEAVE, function(e:* = null):void { allowBrowserScroll(true); } );
  static private function allowBrowserScroll(allow:Boolean):void
   createMouseWheelTrap();
   if (allow == _browserScrollEnabled)
    return;
   _browserScrollEnabled = allow;
   if (ExternalInterface.available) {
    ExternalInterface.call(JS_METHOD, _browserScrollEnabled);
    return;
  static private function createMouseWheelTrap():void
   if (_mouseWheelTrapped)
    return;
   _mouseWheelTrapped = true;
    ExternalInterface.call("eval", JAVASCRIPT);
    return;
Then you call it in your main.mxml with:
import com.esri.ags.script.MouseWheelTrap;
This seems pretty straightforward, but I get the error, "1120: Access of undefined property stage" when I compile. There must be a simple fix to this that I'm not getting... Any Ideas?
Thanks for your help.
JohanMeijer
Should the javascript implementation also work on the flexviewer (we are still using V2.4) when embedded via an I-frame into another website, like: http://www.pbl.nl/en/roadsfromrio/trends-in-biodiversity-loss
Do I need to change the "myId" value to flashcontent?
For some reason the browser keeps scrolling...
I also can't get the MouseWheelTrap flex variant in action. Like JALevine mentions: it compiles without error, but no change in the website.
Any help appreciated!
Johan
AaronNash1
I was able to get mouse trap working, not in the flexviewer but in an Iframe with a simple map. Displayed is the actionscript file, and just initialize this function on startup
   private function init():void
package com.sample
 import mx.core.Application;
 import mx.core.mx_internal;
  * MouseWheelTrap - Simultaneous browser/Flash mousewheel scroll issue work-around
  * @version 0.1
  * @see http://www.spikything.com/blog/?s=mousewheeltrap for updates
  * (c) 2009 spikything.com
public class MouseWheelTrap {
 static private var _mouseWheelTrapped :Boolean;
 public static function setup(mainStage:Stage):void {
  mx.core.FlexGlobals.topLevelApplication.addEventListener(MouseEvent.ROLL_OVER, function():void{
  //i added 'mx.core.FlexGlobals.topLevelApplication.'making it work better for flex. use 'stage' for flash
  mx.core.FlexGlobals.topLevelApplication.addEventListener(MouseEvent.ROLL_OUT, function():void{
 private static function allowBrowserScroll(allow:Boolean):void
  if (ExternalInterface.available){
   ExternalInterface.call("allowBrowserScroll", allow);
 private static function createMouseWheelTrap():void
  if (_mouseWheelTrapped) {return;} _mouseWheelTrapped = true;
   ExternalInterface.call("eval", "var browserScrolling;function allowBrowserScroll(value){browserScrolling=value;}function handle(delta){if(!browserScrolling){return false;}return true;}function wheel(event){var delta=0;if(!event){event=window.event;}if(event.wheelDelta){delta=event.wheelDelta/120;}else if(event.detail){delta=-event.detail/3;}if(delta){handle(delta);}if(!browserScrolling){if(event.preventDefault){event.preventDefault();}event.returnValue=false;}}if(window.addEventListener){window.addEventListener('DOMMouseScroll',wheel,false);}window.onmousewheel=document.onmousewheel=wheel;allowBrowserScroll(true);");
I tried using the javascript, it worked when the map was embedded on the page but not when the map was in an iframe.
