Design Mode Error
1970
05-12-2010 07:31 AM
LynnCarlson__GISP
Hi - Just started working with Flash Builder 4 and ESRI Flex beta 2 api.  I cannot "see" anything in Design mode. The description of the problem reported by Flash Builder is "Design mode: Error during component layout. Choose Design > Refresh to refresh design mode."  The Location is "Unknown" so I cannot get a line number for my code.
Refreshing in design mode does not resolve the problem.
This is just a warning, so I am able to proceed and view the application, but I've lost the functionality of being able to place other components (buttons, etc.) by drag and drop.
I created a new project and did some design work first, but as soon as I added in the esri:Map tag, the Design mode fails in this project as well.
Help!
Also, the ESRI components are no longer appearing in the components tab of Flash Builder.  In Flex Builder 3, along with Controls, Layout, etc. there was an ESRI folder from which you could drag/drop a map component.  Why are these no longer appearing there?
Thanks for any advice.
by Anonymous User
Not applicable
Original User: Lynn_Carlson
Thanks very much for leading me to this answer!  I appreciate it.
Best, Lynn
