Date format in a DataGrid
2041
7
12-09-2010 06:37 AM
KathleenBrenkert
Is there an example anywhere of how to format a date field for a datagrid? I've  tried calling a labelFunction but  anytime I apply a dateformatter using code I get nothing returned.  I've tried a few variations of the code below.
public function getDateLabel(item:Object,column:DataGridColumn):String
return dateFormat.format(item[column.dataField]);
RobertScheitlin__GISP
Kathleen,
   Here is my date label function:
private function getDateLbl(item:Object,column:DataGridColumn):String
    var dateMS:Number = Number(item[column.dataField]);
    var retVal:String = "";
    var rVal:String = item[column.dataField];
    if(rVal == null)
     //do nothing
    }else{
     if (!isNaN(dateMS))
      retVal = msToDate(dateMS, _dateFormat);
    return retVal;
KathleenBrenkert
is the msToDate a function you have written? I get an error on that line.  I'm guessing it's a millisecond to date function?
Kathleen,
   Yep, I did forget to include that 😮
   private function msToDate(ms:Number, dateFormat:String):String
    var date:Date = new Date(ms);
    if (date.milliseconds == 999) // workaround for REST bug
     date.milliseconds++;
    if (dateFormat)
     dateFormatter.formatString = dateFormat;
     var result:String = dateFormatter.format(date);
     if (result)
      return result;
     else
      return dateFormatter.error;
    else
     return date.toLocaleString();
KathleenBrenkert
Thanks Robert it's just what I needed.  The only problem I have now is it's not catching the rest date bug and all my dates are coming up as 1 day early.  Can you tell what I've done wrong with my msToDate code?
    var date:Date= new Date(ms);
    if (date.milliseconds==999)
    if (dateFormat)
     var result:String=mydateFormat.format(date);
     if (result)
      return result;
     else
      return dateFormat;
    else
Kathleen,
   Are you running ArcGIS Server SP1?
KathleenBrenkert
I installed the service pack this morning but I still have the date problem.
KathleenBrenkert
I changed the code to read:
date.milliseconds=date.milliseconds + 86400000; \\adds a day
I also took out the if statement to force it to add a day every time.  I'm not too happy with this fix, but it's been the only thing to get my dates to actually show up correctly in this application.  Every other web app I have programmed I add a millisecond and its works fine.
