Data Extract Add Scrollbar?
1583
04-18-2011 06:56 AM
Langan_1Langan_1
Is there a way to add a scroll bar or view more than 4 layers on the data extract widget?  I have serveral layers that I would like to provide the user with the ability to extract.
BjornSvensson
Esri Alum
The scroll bar should be added automatically. Are you seeing something different?
Langan_1Langan_1
I am not seeing this.  The toolbar is locked (using config-all) at the bottom of the web page and it appears that a portion is being cutoff on the right.  It also does not allow me to expand.  There is a scroll bar on the right, but this only allows me to see the steps (i.e., 1-4).  I have approximately 30 layers in the GP Service and step 2 only shows the first 4.   Can i unlock and allow to expand?  Should there be a second scroll bar on the right for Step 2 if i have more than 4 layers?
BjornSvensson
Esri Alum
It "should" work.
Try using it in a floating widgetcontainer instead of horizontal mode.  This will have the added benefit of people being able to resize the widget - which might be handy if you have 30+ layers...
Are you using the 2.3 version that we released last week?
xingwenchen
Hi, Bjorn,
I tried to use the extract widget on my flex website. In ArcGIS Server, the virtual directories such as arcgisoutput & arcgisjobs are set up as: http://localserver/arcgisoutput or http://localserver/arcgisjobs. When I run the widget extract features, it does extract the data and I can find in the local directory, but the widget directs the download to the local URL as well, like: http://localserver/arcgisjobs/services/....., of course, it won't be found. What change do I need to make to let the download direct to the internet URL like http://gis.mydomain.com/arcgisjobs/services/...? (I tried to substitute the download url in the source code to internet url, it does not change, & still direct to the local url). Thank you very much.
Xingwen Chen
