Creating an extent DropDownList
10242
18
10-25-2010 03:59 PM
JasonLevine
   I'm trying to create a bookmark drop down list in my flex app.  I've created the drop down bar with this code:
<s:DropDownList width="164" prompt="Select Your Community">
<s:ArrayCollection>
  <fx:String>Community #1</fx:String>
  <fx:String>Community #2</fx:String>
</s:ArrayCollection>
</s:DropDownList>
My two questions are:
1) Where do specify the extent values (minx, miny, etc...) for each community? Do I do that within the string tag, or do I create a separate xml file with the data?
2) How do I add a function that zooms the map to the extent specified when a city is selected from the drop down list?
Thanks for your help,
Jason
KenBuja
MVP Esteemed Contributor
The first line in the try block (line 38) should be
var loader:URLLoader = URLLoader(event.target)
KenBuja
Have you stepped through the code using the debugger? I would put a breakpoint at the If statement and check your variables to make sure you have properly read in the XML file. I've attached a screenshot of the XML list variable I get from my code. In this particular project, I'm not using the Extents node, but I've expanded out one of the nodes I am using (which also populates a combobox)
JasonLevine
Hi Ken,
    I managed to compile it all without any errors, however, the values in the xml don't seem to be loading into the Combobox.  where do I call the init() function?  Is it something like this?:
<?xml version="1.0" encoding="utf-8"?>
<s:Application xmlns:fx="http://ns.adobe.com/mxml/2009"
      xmlns:s="library://ns.adobe.com/flex/spark"
      xmlns:mx="library://ns.adobe.com/flex/mx"
      xmlns:esri="http://www.esri.com/2008/ags"
      xmlns:container="com.esri.ags.script.*"
      initialize="init()" >
KenBuja
I have that in the creationComplete event
JasonLevine
I added it to the creationComplete event, and the xml values still don't load in the combobox.  See anything wrong with my code?
Jason
Here are the functions:
//the following two functions import the bookmarks.xml file
   private var xmlParameters:XML;
   public var xmlProjectParameters:XMLList;
   private function init():void
    var xmlLoader:URLLoader = new URLLoader();
    xmlLoader.load(new URLRequest("bookmarks.xml"));
    xmlLoader.addEventListener(Event.COMPLETE,init_onComplete);
   private function init_onComplete(event:Event):void
    var extentArray:ArrayCollection = new ArrayCollection;
    try
     xmlParameters = new XML(loader.data)
     xmlProjectParameters = xmlParameters.communities.(@id=="communities")
     if (!(xmlParameters.extents == undefined))
      dropdown.visible = true;
      for (var i:int = 0; i < xmlProjectParameters.extents.extent.length(); i++)
       extentArray.addItem({label:xmlProjectParameters.extents.extent[email protected](), xmin: xmlProjectParameters.extents.extent[email protected](), ymin: xmlProjectParameters.extents.extent[email protected](), xmax: xmlProjectParameters.extents.extent[email protected](), ymax: xmlProjectParameters.extents.extent[email protected]()});
      dropdown.dataProvider = extentArray;
    catch(e:Error)
     Alert.show("Error: " + e.message);
     return;
   //Zoom to your community tool
   public function change():void
    var extent:Extent = new Extent(Number(dropdown.selectedItem.xmin), Number(dropdown.selectedItem.ymin), Number(dropdown.selectedItem.xmax), Number(dropdown.selectedItem.ymax))
    myMap.extent = extent;
Here is my bookmarks.xml file:
<bookmarks>
  <communities id="communities">
 <extents>
   <extent name="Community #1" xmin="-13181026" ymin="4010315" xmax="-13164974" ymax="4017443"/>
    </extents>
  </communities>
</bookmarks>
JasonLevine
Problem solved.  I removed the try and catch and shortened it up a bit:
Jason
MarcGuidry
Sorry to dig up an old thread but...
I've got my combo box working but I was wondering how to get the combo box selection to reset after a selection has been made?  That way you can select the first extent, pan around, and go back to that first extent without having to select a different extent first.
EvelynHernandez
Add the features from the last choosen to an arraylist or arraycollection variable, then when u wanna go back u will pass those values to the zoom extent.
denverweston
Hey Jason,
Do you have the updated code for this drop down?  My combobox will still not populate using the code above.
