create new infosymbol
1493
7
09-14-2010 03:15 AM
yanli
how do i create infosymbol with C#
   <esri:InfoSymbol id="infoSymbol1">
        <esri:infoRenderer>
            <mx:Component>
                <mx:VBox >
                    <mx:Label  text="{data.myphone}"/>
                                    </mx:VBox>
            </mx:Component>
        </esri:infoRenderer>
    </esri:InfoSymbol>
private function addsymbol():void{
     var myGraphic:Graphic=new Graphic(new MapPoint                       (66669.794213,42498.544789));
                  myGraphic.symbol=infoSymbol1;
               myGraphic.attributes["myphone"]="123";
                        myGraphicsLayer.add(myGraphic);
what's the error here? can't see  the label in the symbol box
yanli
nobody can help me?
the mxml code like this  is ok..
<esri:Graphic>
                <esri:geometry>
                    <esri:MapPoint x="61669.794213" y="45498.544789"/>
                </esri:geometry>
                <esri:attributes>
                    <mx:Object>
                       <mx:myphone>riri</mx:myphone>
                          </mx:Object>
                </esri:attributes>
            </esri:Graphic>
but is write with AS code  following is error
     var myGraphic:Graphic=new Graphic(new MapPoint(66669.794213,42498.544789));
               myGraphic.attributes["myphone"]="123";//the error here!!!!!
can you help me...  thank you
RobertScheitlin__GISP
Yan,
   I think you had us all scratching our heads with this part
Now that we know you really mean ActionScript code and not C# it a little easier to answer your question.
Here is the proper syntax for your code:
    var myGraphic:Graphic=new Graphic(new MapPoint(66669.794213,42498.544789),infoSymbol1,{myphone: "123"});
yanli
Thank you for your reply..it is ok
while i try the code like this is error
var myGraphic:Graphic=new Graphic(new MapPoint(66669.794213,42498.544789));          myGraphic.symbol=infoSymbol1;
     myGraphic.attributes=new ArrayCollection([
                                     {myphone: "123"}
how do create a new myGraphic.attributes? thank  you
Yan,
   The way that I suggested in the last post works perfectly but if you must build the attributes separately than here is how
var attribs:Object = {myphone: "123"};
myGraphic.attributes=attribs;
yanli
myGraphic.attributes can be a Arraycollection?
Yan,
  If you look at the documentation for a graphic object it is wanting an Object for the attributes property.
http://help.arcgis.com/en/webapi/flex/apiref/com/esri/ags/Graphic.html
yanli
thank you for your reply ..
while  i find the example of '   query result  as chart ' in
http://resources.esri.com/help/9.3/arcgisserver/apis/flex/samples/index.html
in which the myGraphic.attributes is definited as a  ArrayCollection
while i try definite the  myGraphic.attributes  like the example is error .
