Could anyone help me ..
1147
5
06-11-2010 03:48 AM
sandrocosta
how to manipulate data from metadata using the flex api 2.0?
RobertScheitlin__GISP
Img,
   As metadata is not exposed by REST endpoints the only way to work with metadata is by using Arcobjects or SOAP through a dot net web service. If you have questions on doing that they will be best answered on the forums that are specific to those technologies.
sandrocosta
Thanks rscheitlin!
sandrocosta
rscheitlin,
there is even no way you do, for example: is it possible to expose services (geoprocessing) metadata via ArcGIS Server in version 10? or by using python script that you can also publish scripts on the ags?
Img,
   Almost anything is possible using python and geoprocessing services. I would not know where to begin though.
sandrocosta
I will try to follow that line ... if you have put progress in the post, once again, thanks!
