Correct method for sending graphics array for reproject
903
07-27-2010 09:16 PM
DrewDowling
I need to send a collection of points to a geometry service for reprojection. The points are in a graphics layer from when the users clicked on the map.
the code I am using is:
var arraycollhope:Object;
arraycollhope = myXYGraphicsLayer.graphicProvider
var outSR:SpatialReference = new SpatialReference(2230);
geometry1.project(arraycollhope.toArray(), outSR);
where myXYGraphicsLayer is the graphics layer.
This seems to work but what i don't understand why. arraycollhope is defined as an object not as an array collection. If I define it as an array collection I get an implicit conversion error as myXYGraphicsLayer.graphicProvider returns an object. Yet when I call the method .toArray it appears to work, even though this isn't a method on IObject. To me this implies an implicit conversion anyway.
Is there another preferred way of doing this?
Thanks for any help or comments
Drew
RobertScheitlin__GISP
Drew,
   The way that you are doing it is fine. The graphicProvider of a graphicsLayer return value is type object (normally that object is an array collection). You could do
var arraycollhope:ArrayCollection;
arraycollhope = myXYGraphicsLayer.graphicProvider  as ArrayCollection;
The project method is expecting and Array (not ArrayCollection) so that is why you have to use
DrewDowling
Thanks Robert, helpful as always.
This still feels a little hokey to me. I basically had to guess that myXYGraphicsLayer.graphicProvider returned an array collection. It's kind of obvious but if I had to guess here I'm worried that there are other places down the line that it won't be obvious.
I like your way of using the "as ArrayCollection;" declaration during the assignment. Its a little more structured.
Cheers
Drew
