Convert Coordinate in Degree
918
08-23-2011 10:09 AM
AzizulAlam1
I have set up the coordinate pop up but it is showing in meter. I want to display it in Degree Min Sec format. How can I do it?
RobertScheitlin__GISP
Azizul,
   If you are speaking of the coordinate widget for the Flex Viewer than look at it's documentation here:
http://help.arcgis.com/en/webapps/flexviewer/help/01m3/01m300000016000000.htm
If you are speaking of one you created then still look at the code in the CoordinateWidget.
If you are going to do your own developing than you need to learn from other developers work by looking at thier source code.
