Connect with cofig file dynamically.
627
05-10-2010 10:25 PM
KiranVyas
I am using sample flex viewer.Now  I want to connect with cofig file dynamically i.e. in ConfigManager.as
     switch(Application.application.deptCode)
          case 1: //connect with department1 config file
          case 2: //connect with department2 config file
Each department has its associated cogif file.Now in HomePage I created buttons.When user clicks on Department1 button cofig1 should be loaded and so on.I defined one variable
    [Bindable]public var deptCode;
On buttton click i am changing value of this variable But when i access this variable in my ConfigManager file then it is creating problem.Further code of ConfigManager  doesn't execute  whenever i access this variable.
Please help me how to access this Homepage variable in ConfigManager.as file.Is another alternative exists.
