Clustering questions
767
04-04-2011 09:46 AM
TyroneLigon
I noticed in the Flex API that the graphics layer has a clusterer property, so I assume you can apply clustering to graphics added to a graphics layer. In our app, we add graphics with picture marker symbols to a graphics layer. I have a couple of questions:
  • When the cluster flares out, can the original marker symbols be used?
  • If the answer to the first question is yes, do the rollover, rollout, tool tip, and click functions assigned to the graphic still work?
RobertScheitlin__GISP
Tyrone,
   Clustering and Flare are two different things... You can cluster your PictureMarker symbols but to cluster and flare PictureMarker symbols you have to use Mansours code here.
http://thunderheadxpler.blogspot.com/2010/08/image-flare-symbol-for-clustered.html
