Clone a Server-based FeatureLayer to a local one?
3757
11
10-08-2010 06:34 AM
CharlieRichman
I'd like to populate a new local FeatureLayer (via its featureCollection) to match the features in a server-based FeatureLayer.  Any suggestions on a clean way do that?
Clearly you can't grab the featureCollection from the source layer -- it's null.  Am I better off running a query against the source layer, or grabbing its graphicsProvider info?  (And how do you create a query that returns all records, anyway?)
Ideally I'd preserver symbology as well...
Thanks, folks.
Charlie Richman
DC Office of Planning
CharlieRichman
Sorry -- that's what I meant to type.
Thanks so very much for all of your help!
Charlie Richman
CharlieRichman
Interesting results with the search by extent.  The selection works, but is slow (3 seconds in my case.)  I assume that's because it's being handled by the browser.  Any tips for optimizing that?  Is this largely a function of polygon count?  Vertex count?  It might be faster for me to query a server-based geometry first and then grab the matching local geography manually.
Using code derived from the AttributeInspectorOutsideMap example, the Attribute Inspector window shows me empty space with my locally-instantiated featurelayer instead of the fields that I get with a server-based featurelayer.  (With a server-based layer I see all fields in default order automatically.)
<esri:AttributeInspector id="attributeInspector"
    left="6" right="6" top="6" bottom="6"
    featureLayers="{[blocks]}"
    formItemsOrder="fieldInspector"
    showFeature="attributesinspector_showFeatureHandler(event)"
    deleteButtonVisible="false">
</esri:AttributeInspector>
  private function attributesinspector_showFeatureHandler(event:AttributeInspectorEvent):void
                highlightGraphicsLayer.clear();
                var g:Graphic = new Graphic(event.feature.geometry);
                g.toolTip = event.feature.toolTip;
                highlightGraphicsLayer.add(g);
In the map:
<esri:FeatureLayer id="blocks">
   <esri:renderer>
   </esri:renderer>
</esri:FeatureLayer>
Is there more that I need to specify to get the attributeInspector to work with my local featurelayer?
Charlie Richman
