Changes Not Visible when Flex Runs
1122
06-16-2010 01:08 PM
BradOleson
I'm making some changes in a Print widget - right now just font size and / or text contents.  The file is the PrintWidgetPdf that Frank Roberts contributed.
When I make my changes and build / run the viewer, the changes aren't happening in the PDF file.
If I make the old PrintWidget the tool that prints, and make similar changes, those changes are visible in the printed output.
My question is - where is the disconnect happening?  Is something not making it to the swf file, and thus the changes aren't being incorporated?  Any help on this one would be appreciated...
Brad
BradOleson
Additional info -
In the Widgets folder, I "see" the PrintWidgetPdf.swf, and the IdentifyWidget.swf when using the package explorer in Flash Builder 4.  I do not see any of the other .swf files in that directory.  Why is this, and could it have something to do with the issue?
Brad
BradOleson
...and I solved it myself.  It helps to add the widget to the list of items being built in the project.
