Blurry Printing
3644
08-03-2012 05:21 AM
Drew
I have been working with the new Print Task this week and noticed that the end result is always a little blurry.
I have tested many formats (PDF, PNG32, PNG8, JPG) and changed the DPI (200 & 1000) in the ExportOptions object but nothing seems to make the map crisp.
I also tested the ESRI sample labeled "High Quality Printing" and it also comes back with blurry map images.
http://resources.arcgis.com/en/help/flex-api/samples/index.html#/High_quality_printing/01nq0000006v0...
Has anyone else experienced this or maybe have a work around?
Drew
DasaPaddock
Instead of retrieving the tiles and stitching them together, the Print GP will make a /export map request to the service if it's a 10.1 service that has dynamic layers enabled on it. This will result in a new image being created from the data since /export will go to the data in this case. In all other cases, /export stitches the cached tiles together.
DasaPaddock
See this tutorial on how to print from the source vector data instead of cached tiles.
http://resources.arcgis.com/en/help/main/10.1/#/Tutorial_Basic_high_quality_web_map_printing_exporti...
Drew
Thanks for the reply Dasa.
Just out of curiosity, why wouldn't the new Print GP service flip the Tiled map service to be a Dynamic map service to ensure there is not loss in quality. I assume it's speed but thought I would ask.
Generally most people should be using one Tiled map service in their mapping application and if the printing always results in a blurry base maps (due to scale change) it seems it would be better to render the Tiled service as a Dynamic service on the server side.
Anyways.. I am going to hack around to see what I can get going here with your post.. Thanks again,
Drew
DasaPaddock
Drew
Dasa,
Thanks again for the reply. I was able to get our maps printing at a decent quality by doing the following.
  • Use a 10.1 service
  • Enable Dynamic Layers on the 10.1 service
  • Changing the dpi to 300 in the ExportOptions object
  • Printing to a standard 8x11 layout
I could have gone the high quality printing way as you suggested in your first post, but my application is mashed up with so many services it would have been a nightmare to manage all the replicated layouts.
Thanks again.
Drew
