Basemap disappears
843
09-21-2012 12:10 PM
LeroyChristophersen
Why does the Basemap from ESRI disappear when used in Flex when I zoom closer than 1:2200, but within ArcInfo, the same image will allow me to zoom in to 1:200?  Is there a way have it available in Flex to the same ratio?
RhettZufelt
MVP Notable Contributor
without knowing more specifically which basemap you are refering to, I would hazard a guess that you are exceeding the tiled scale level of the basemap.
If so, in flex, if you load as type="dynamic", you should be able to zoom in more (just slows it down a bit).
R_
