Auto zoom from larger extent into initial extent
2210
10
05-05-2011 06:55 PM
RobertMyers
Is it possible on opening a flex app to an extent showing a wide area, pause ,then zoom into the initial extent? An example would be to show a State for a second then zoom into a city which would be the area of interest for the flex map.
RobertMyers
I have another post about this problem. http://forums.arcgis.com/threads/30003-Bind-Maps-and-query-results-glitch  If you hit refresh it should correct the problem. Or sometimes clearing the browser cache will fix it.  The points "in Africa" are being reprojected to the web mercator.
The code that I attached previously is the same as the web link code. The query result include outSpatialReference="{myMap.spatialReference}.  myMap has <esri:SpatialReference wkid="102100"/>
I am wondering if it's an issue with the newer Flex API 2.3.
