Attachment Relate Info Window Widget on editable feature layer?
2929
13
04-12-2011 07:42 AM
WilliamBall1
I have a question about the Attachment Relate Info Window Widget.  I can get the widget to work and show related tables, but the problem is that I would like to use it with a couple of editable layers.  If I list the layer as an operation layer in the config.xml it works when I use the MapServer REST endpoint but not when I use the FeatureServer REST endpoint.  I need the FeatureServer layer in order to edit the layer.  I've also tried listing both, but that doesn't work.  Is it possible to use this widget with an editable feature layer?
HaroldBostic
I think Bill's problem was that he did his relate on the manHoleId rather than the objectId.  I am assuming that as I am working with related data that is not related by it's objectId and nothing is working properly.  Is this an accurate assumption?
JustinFultz
Robert,
I am attempting to integrate the the Relate info widget into my application.  When trying to select the related info grid a table comes up with two records, that as far as I can tell are the names of my relationships.  when closing the grid I get the error "Invalid value for the parameter 'relationship id'".
I get this same behavior from your sample site.  Is this something browser related on my end?
Any ideas?
Thanks!
Justin
RobertScheitlin__GISP
Justin,
   You have to select one of the relationships before you click done.
JustinFultz
Sorry. been staring at a computer too many hours today.
time to wrap it up.
