attach/relate widget 2.4 and MapService
1118
08-02-2011 12:29 PM
JohnSegars
If I read correctly the relate functionality should work with a MapService as well as a FeatureService?  Granted I'm just diving into flex and widgets so that could be problem number 1.
is there an example using a MapService out there because thus far I've only seen examples hitting Feature Service endpoints.
thanks,
John
RobertScheitlin__GISP
John,
  Sure that is why there is a folder in the download called "Example Main Configuration files" Look at the config-relate.xml and notice that the layer type is feature yet the url is connecting to a MapServer and not a FeatureServer.
JohnSegars
Thanks Robert!
I looked at it but apparently not close enough!
After a break from the screen and a bike ride things became clear and I pointed things correctly.
Thanks for your work on all those great widgets!!!
John
