ArcServer 9.3 and FlexViewer 2.0
975
09-21-2010 05:37 AM
DeonaEvans
Can someone tell me if it's okay to use FlexViewer 2.0 with ArcServer 9.3?  There is a link to this question in the Concepts/Migrating to 2.0 help documentation on the website but the link doesn't seem to work.
Thanks.
RobertScheitlin__GISP
Deona,
   Yep it will work fine with AGS Server 9.3.1
DerekLaw
Esri Esteemed Contributor
Hi Deona,
Just to add onto what Robert posted, the ArcGIS Viewer for Flex 2.1 release will work with services published from ArcGIS Server 9.3 and 9.3.1 - however some of the Viewer's new functionality won't be available, such as the Edit widget and the Time Slider widget.
Hope this helps,
DeonaEvans
Yes, this all helps.  Thanks to both of you!
