ArcGIS Online Spatial Analysis
6323
01-27-2015 05:13 AM
AnishKumar1
I am using ArcGIS API for flex for developing ArcGIS Server based solutions.
Currently, I am working on ArcGIS Online Service, where I am able to use services provided by ArcGIS Online but I am unable to access ArcGIS Online Spatial Analysis Services.
I want to know the procedure of calling Spatial Analysis Services.
If anyone knows how to access ArcGIS Online Spatial Analysis Service, kindly let me know the workflow to access the Services,
Thanks in Advance
Anish Kumar
KellyGerrow
Esri Alum
Hi Anish,
To access the analysis services hosted in ArcGIS Online, you will need to follow the steps listed in this documentation:
https://developers.arcgis.com/rest/analysis/api-reference/programmatically-accessing-analysis-servic...
Kelly
AnishKumar1
Hi Kelly,
Thank you for the reply. I have gone through this link before, but there were some problems which I was not able to sort out.
For accessing this Spatial Analysis Service we need token, there is a term "portal_url" which I am not getting what exactly it is.
Kindly help me to figure out this problem.
Thanks
Anish Kumar
KellyGerrow
Esri Alum
HI Anish,
As you are using ArcGIS Online as your portal, use the following URL to work with the script:
https://arcgis.com/sharing/rest
The portal URL indicates which portal you are generating the token from.
Kelly
AnishKumar1
Hi Kelly,
Thank you for this information.
Thanks & Regards
Anish
