ArcGIS Flex API and Oracle SDE
1128
04-07-2011 06:56 PM
ParikshitRanade1
Is there any help for ORACLE and Flex.
JustinGreco
There isn't help with the Flex API and Oracle SDE.  What exactly do you need help with?  If you need help setting up ArcGIS Server to use Oracle SDE connections for your services, I'd suggest looking at the ArcGIS Server help.
If you are looking to connect Flex with your Oracle database to perform SQL queries, you need to set up a backend script (PHP, BlazeDS, etc).  There is plenty of help articles on Adobe's site.
ParikshitRanade1
Justin,
Thank you very much for the help. Sorry it was very vague question. I posted details on Flex Viewer forum
http://forums.arcgis.com/threads/27792-ORACLE-ArcSDE-and-Flex
We need to develop a Flex Web Editing application using ORACLE SDE geodatabase. It is versioned geodatabase. Multiple  users need to securely access ArcSDE versions (only their own version)  from Flex Web Application.
Any reference/help from Flex programming side  to access and manipulate database would be greatly appreciated.
Thank a lot.
MSInc
