ArcGIS API for Flex 2.5 released December 2, 2011
4591
14
12-02-2011 08:54 AM
BjornSvensson
Esri Alum
See what�??s new for API at http://help.arcgis.com/en/webapi/flex/help/index.html#/What_s_new/017p0000000w000000/ - you might have to wait 15 minutes for the server to show the "2.5" pages...
RobertScheitlin__GISP
Begirl001,
  One what?... Do you mean where to download the Flex API? If so here is the link:
http://resources.arcgis.com/content/arcgis-flex-api-how-to-download
NasifAlshaier
HI bjorn
is there a way to contact the person who created the Closest Facility widget?
thanks
Nasif
BjornSvensson
Esri Alum
For any code gallery item, you can always use the "Comments" section of that item.  Often asking the question on the forum can be better as more people might be able to help (or have the same question).
For the Closest Facility Widget, there was also a blog entry - http://blogs.esri.com/esri/apl/2010/11/08/a-pair-of-new-flexviewer-2-1-widgets/ - where you could also submit a question.
MinChingChen
Will the current Flex 2.5 APPs continue to work with ArcGIS Server 10.1?
BjornSvensson
Esri Alum
Yes, any Flex API applications (from 1.0) will continue to work with ArcGIS 10.1 (as well as any other ArcGIS Server since 9.3).
