Any guide to write server side code?
1430
10-23-2012 06:58 PM
XintaoLiu
If I want to do some job on server side, and then transfer the results to client, how to implement it?
Any reply and suggestion is highly anticipated and appreciated.
AnthonyGiles
Honored Contributor
Xinato,
There are various examples in the help files that provide step by step instructions on setting up geoprocessing services:
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#/Guide_to_the_geoprocessing_service_exa...
Hope these are of some use
Regards
Anthony
IvanBespalov
ArcGIS for developers
1,
ArcGIS REST API for 10.1
SOAP SDK
AnthonyGiles
Honored Contributor
Xinato,
Regards
Anthony
XintaoLiu
Thank you guys! After creating a geoprocessing tool, then we can call it from the client. Are there any examples? I should Google it by myself, but if it is convenient for you, the answers are highly appreciated.
AnthonyGiles
Honored Contributor
Xinato,
Once you have got your geoproceesing service running on your server you can use the geoprocessing widget (if you are using the flex viewer) to run your gpservice:
http://resources.arcgis.com/en/help/flex-viewer/concepts/index.html#/Geoprocessing_widget/01m3000000...
If you are just using the API, you will need to write your code, some example can be found here:
http://resources.arcgis.com/en/help/flex-api/samples/index.html#/Population_for_any_area/01nq0000002...
Regards
Anthony
