"Tutorial: Advanced high-quality web map printing" as widget. How to get a xml?
835
10-31-2013 06:44 AM
JeffersonFerreira_Ferreira
Hello all,
I follow the tutorial: Advanced high-quality web map printing/exporting using arcpy.mapping and its great.
But I'm trying to put it in my aplication as a widget. How I could build a xml to that compiled swf from tutorial?
Any ideas will be appreciated.
Thanks in advance
YueWu1
by Esri Regular Contributor
Hi Jefferson,
If you was changing the edit widget according to your custom application, you would need to make changes to the .xml file present at the below location: C:\Inetpub\wwwroot\flexviewer\widgets\Edit\EditWidget.xml
You don't need to make any changes to the .swf files present. If you would be working with the Source code in Flash builder  and creating any custom widget in an mxml file, once you builds that mxml file it would generate a .swf file
Hope this answer your question.
