Adding a secured ArcIMSMapServiceLayer to the sample flex viewer
1492
6
06-22-2010 06:21 AM
JasonReid
Having some difficulty using a secured arcIMS service in the default flex viewer. I made the changes to the ConfigManager and MapManager to handle arcIMS services. The layer shows up, however it prompts for a username and password even though I put those in the config.xml and handle those properties in the connection.
Anyone have any suggestions?
DasaPaddock
Is it using Basic or Digest authentication? Only Basic is supported in the API:
http://resources.esri.com/help/9.3/arcgisserver/apis/flex/apiref/com/esri/ags/layers/ArcIMSMapServic...
JasonReid
The source is using basic authentication. It's the WeatherBug® GIS Data Services I'm trying to use. I can add the serivice into a default map application in server and have no problems so this is a flex app problem I can't find the problem.
I'll attach a text file with what changes I made to the flex viewer. Maybe someone will see what I'm missing.
DasaPaddock
Can you try this in the Flash Debug player to see if you're getting any errors?
http://www.adobe.com/support/flashplayer/downloads.html#fp10
Can you try a tool like HttpFox to see if the Authorization header is being sent in the request and what the response from the server is?
https://addons.mozilla.org/en-US/firefox/addon/6647/
You may also want to try creating a simple test app first like this one before trying it in the Viewer:
http://resources.esri.com/help/9.3/arcgisserver/apis/flex/samples/index.html?sample=ArcIMS
JasonReid
I've narrowed this down to a network problem, which makes this even more difficult to track down the problem.
DavidKiendl
you can rehost the IMS weather service from weather bug as a wms. This method only seems to work in 1.3 sfv though no luck with 2.x. Load the feed into an mxd or msd and publish as wms.
JasonReid
I'll try this see if it works. Unfortunatly the latest 2.1 viewer doesn't support secured ArcIMS services either. I'll need to figure out a proxy if the wms trick doesn't work.
