Add image to map from custom widget
706
06-13-2013 11:48 AM
ErikMartin
I have a custom widget in the Flex Viewer and I would like to add an image to the map via ActionScript in my custom widget. The following works when it is called in the code, but it adds the image at the bottom of my widget, not in map:
At the top:
private var img:Image = new Image;
then the function:
private function addImage():void
 trace("trying to add legend")
 img.source = "assets/images/image.png";
 this.addChild(img)
When I try the following, the trace happens, but no image is added.
 map.addChild(img)
Any advice would be appreciated.
-Erik
