Problem with Full Motion Video ArcGIS. Empty output file.
3450
8
05-29-2018 08:13 AM
PrzemysławKapeluszny
I'm trying to create video with georeference using Full Motion Video.
When I use a video multiplexer, the process ends positively, but the result is a file with a size of 0 KB, which I can not read later.
I also try do this on data from Esri tutorial with the same result.
Thank you in advance for help and hints what may be wrong.
It turned out that in my Windows 10 system, a comma separator was used as
the default separator instead of a dot.
It was not enough to change the separator only in Excel, but I also had to
change the separator in the Windows settings.
Problem solved
pt., 1 cze 2018 o 19:09 Cody Benkelman <[email protected]> napisał(a):
GeoNet <https://community.esri.com/?et=watches.email.thread>
Re: Problem with Full Motion Video ArcGIS. Empty output file.
reply from Cody Benkelman
<https://community.esri.com/people/CBenkelman-esristaff?et=watches.email.thread>
in AEC (Architecture, Engineering and Construction) - View the full
discussion
<https://community.esri.com/message/776263-re-problem-with-full-motion-video-arcgis-empty-output-file?commentID=776263&et=watches.email.thread#comment-776263>
RafaelFernandes
Esri Alum
Hi Przemysław Kapeluszny
Unfortunately, I don't know much about the Full Motion Video (FMV) solution. I would recommend discussing this with issue with Cody Benkelman the product manager for FMV. He is going to want to know what version Desktop and the FMV plugin you are using.
Good luck,
Rafael
Thanks for quick response.
Desktop 10.5.1
FMV 1.3.2
śr., 30 maj 2018 o 19:27 Rafael Fernandes <[email protected]> napisał(a):
GeoNet <https://community.esri.com/?et=notification.mention>
You have been mentioned
by Rafael Fernandes
<https://community.esri.com/people/RFernandes-esristaff?et=notification.mention> *in
Re: Problem with Full Motion Video ArcGIS. Empty output file. in GeoNet*
- View Rafael Fernandes's reference to you
<https://community.esri.com/message/775662-re-problem-with-full-motion-video-arcgis-empty-output-file?commentID=775662&et=notification.mention#comment-775662>
CodyBenkelman
This is typically a problem with the UnixTimeStamp data.
Since you said the same happened with the tutorial data, it is possible you did this:
1) open metadata csv file in MS Excel
2) save file
3) try multiplexer
If you do the above without adding step 1.a.) BE SURE TO SET THE TIMESTAMP FIELD FORMAT FORMAT TO "NUMBER" then MS Excel converts the data to scientific notation and effectively corrupts your UnixTimeStamp.
another possibility is if your UnixTimeStamp records are milliseconds vs. microseconds.  It needs to be a 16 digit number (but this should not have been a problem with the tutorial data).
If that does not work please upload your metadata file.  (I don't need the video)
Cody
I think format should be ok, because it is original tutorial data.
Metadata file in attachment.
Przemek
discussion
<https://community.esri.com/message/776032-re-problem-with-full-motion-video-arcgis-empty-output-file?commentID=776032&et=watches.email.thread#comment-776032>
CodyBenkelman
Przemek
I ran this tutorial data and it worked fine.  Just to clarify, you are trying to multiplex the tutorial data (01425001.csv and 01425001.mpeg) and your output file is zero size?
Do the tutorial videos play properly in FMV?   Have you tried any of the other geoprocessing tools?  I am wondering if your installation of the add-in was completely successful.
Cody
Yes, I ran this two files and output is zero size.
In tutorial data I have also georeferenced video and it looks good ( i see
marks on the map).
Maybe it is something wrong with instalation but I tried three times with
versions 10.6, 10.5, and 10.5.1 of ArcGis Desktop with appropriate version
of FMV.
discussion
<https://community.esri.com/message/776139-re-problem-with-full-motion-video-arcgis-empty-output-file?commentID=776139&et=watches.email.thread#comment-776139>
CodyBenkelman
Przemek
I have spoken to our Technical Support staff, and this sounds like an installation problem.  Can you please log a tech support incident with them, and they can do a screenshare meeting to determine what is wrong.
https://support.esri.com/en/contact-tech-support
Thanks
Cody B
Problem solved
discussion
