import revit problem
1022
09-08-2020 01:20 AM
LucioLeoni
We are trying to import a revit file in a local 3d scene, but the imported revit, apparently without reason, goes under 2D layers and is not visible in the scene. We tried with other files, sometimes it works correctly, sometimes no.
Suggestions?
Thanks
Tags (1)
DanielChantlos
Hi Lucio,
Are you able to share the Revit file? Was it georeferenced? I could take a look at this further if you are able to share the file.
