hi, I have imported shape files into ArcGis Pro and would like export this now to Autocad, is there a way ?
1485
10-04-2020 02:00 AM
Cornielvan_Wijk
cant find anywhere a step by step guide exporting it, and this surely should not be rocket science?
Please Help
David
by Esri Contributor
From the Analysis tab, you can click on the red toolbox to open the Geoprocessing Pane. Type the word CAD into the search bar to find the Export to CAD too. Click it to open the tool and select your shapefile as the input. Give the output a name & hit Run at the bottom.
David
by Esri Contributor
Cornielvan_Wijk
thanks worked like a charm
