ERROR 000042: Failed to create the address locator. An invalid SQL statement was used. Anyone know why I get this error?
4008
8
10-10-2016 01:13 PM
HannesZiegler2
I am attempting to build an address locator out of the street centerline dataset from Palm Beach County: Information Systems Services Data Catalog
However, when I attempt to create an address locator from the data using the following options, I get an error message stating:
Has anyone encountered this problem or have an idea what the source of this error could be?
I appreciate the help!
AllisonGoldberg2
Hannes,
Were you ever able to solve this issue? I have gotten the same error with PBC data.
Allison
MichaelVolz
Esteemed Contributor
Can you try exporting your data into a file gdb and then see if you can build the address locator?
Was version of ArcGIS Desktop are you working in?
AllisonGoldberg2
It is in a file gdb and I have tried it on 10.2.2. and 10.5.1.
MichaelVolz
Are your To and From fields defined as numbers or text?
HannesZiegler2
I was never able to resolve the issue, I ended up using the google geocoding service.
GPS Visualizer's Easy Batch Geocoder: Convert addresses to coordinates
AllisonGoldberg2
As numbers
MichaelVolz
STREET_NAM is defined as double.  I believe that needs to be a text field.
AllisonGoldberg2
That worked, thank you Michael!
