Records in a Point Featureclass without any vertices..
1589
10-28-2016 07:41 AM
HannesZiegler2
Hi, I have a featureclass of points that I geocoded, but some points were unmatched, and while a record of them exists in my Point Featureclass, these don't have point coordinates. When I start an edit session, and then on the Edit Vertices toolbar go to Edit Sketch Properties, I can't enter coordinates for the point manually.
What's up with that?
**UPDATE**
I used Python Window in ArcMap to see what's up with the geometry, and I found that all points have a value of None.
Now.. when I try to update the geomtry with an update cursor, I get nothing..
Very strange. Any suggestions?
JayantaPoddar
Vertices exist only in lines and polygons, not in Point features.
You might like to start editing for the layer and edit the values in attribute table.
Think Location
HannesZiegler2
In correction, I mean points (XY coordinates for the Point Featureclass). I'm not trying to edit the attributes, I need to give coordinates features.
JoeBorgione
There used to be a method available to do exactly what you are asking;  I'll do some searching and hopefully get back here with it....
moments later:
How To: Manually place unmatched records after geocoding
Review addresses—ArcGIS Online Help | ArcGIS
Exercise 4: Geocoding addresses in a table and rematching unmatched addresses—Help | ArcGIS for Desk...
That should just about do it....
