How to import MXD files into a model builder using script tool?
1383
03-25-2018 03:36 PM
FaridaKhatoon
 using the #python script.
DanPatterson_Retired
What data do you want to add?
You in essence use the same tools that you would use in ArcToolbox... just drag them on to your model, specify your parameters, set your environments and connect outputs to inputs if you have a multistep model.
The workflow is just like you do it manually, so if you can do that, then your model is half done.
FaridaKhatoon
Thank you Sir,
Farida.
Sent from Mail for Windows 10
