Conversion to .eps problems?
2577
04-16-2015 11:20 PM
JohannesBierer
If I convert a map to eps to work with it in a graphic software some text things look loke this:
Even with embedded fonts?
Any ideas?
DanPatterson_Retired
if you can't remove the tags in the generating software, you are going to be stuck with them in Arc* when converted to an image, try an output vector format if available
JohannesBierer
Gracias
