TIN to Raster problem
2583
02-04-2011 04:09 PM
EthanJackson1
Hello
I have a very simple TIN created from four points forming a rectangle. Two points have a Z value of 0. The other two have values of over 7000. I am trying to convert this TIN to a raster, but every time I do it the raster that is created either isn't visible or it's located in the wrong place. Either way, the range of values for the raster is only 0-1.
Anyone know where I'm going wrong or what I can do to make this work?
Tags (1)
KhalidDuri1
Can you share the TIN you created and provide the parameters used in the TIN to Raster tool?
Regards,
Khalid
MichaelStead
If your rectangle is in the vertical plane (ie xy coordinates are the same for base elevation (0) and top elevation (7000+) then you may have to move the x or y a millimeter over for the points overlying each other. I think this problem was supposed to be fixed, but I have run into it creating 3d drillholes when you have a completely vertical section.
Sounds more like some sort or other problem with the data showing up in the wrong location though.
