TIN has vertical faces at Extents Boundary
1315
07-24-2013 06:55 AM
NickMoylan
I am have been creating TIN using the Las Dataset to TIN tool.  I am setting the Extents in the environment settings of the tool to be the same as a bounding box polygon.  the problem arises only at the edges of the extents polygon; vertical faces are created at the edges of the TIN surface.
Is there a way to prevent these vertical faces during the generation of the TIN, or remove them afterwards?
Any help is appreciated,
-Nick
[ATTACH=CONFIG]26175[/ATTACH]
Tags (1)
JeffreySwain
Have you tried to delineate the triangles?  That may be the best option, unless you have a polygon at the outside of your data to use as the clip.
