Raster to KML
2788
6
05-15-2012 06:58 PM
BethNorton
I have raster data that I can show in 3D in ArcScene.  It is flood depth data and I can show the depth up a side of a 3D building.  I would like to show it in Google Earth but I can't get the raster layer into GE while still showing the elevation information.  Does anyone know how I can accurately the raster data into a KML?
Beth
Tags (1)
TimothyHales
Esri Notable Contributor
Have you tried the Layer to KML tool?  Also, do you have a vertical exaggeration applied to the scene?
BethNorton
I have tried it but it is just a flat layer.  I don't know that vertical exaggeration is the right term but it is vertically accurate and looks '3D.'
JeffreySwain
What you may consider is converting the raster to a TIN, create a polygon that covers the desired area and then use the Interpolate Polygon to Multipatch.  This will create a 3d object, which should display as 3d in Google Earth.  I do not think that Google Earth offers the 'Base Height' Functionality that is available with ArcGlobe/ArcScene.  The 3d Object should display in Google Earth in 3d like the other models do.
BethNorton
How do you get the multipatch into GE?  I have made it into a collada and that doesn't have any data in it.  But I can't get the multipatch to load.  And thanks for the help.
JeffreySwain
You will still have to export the multipatch into a .dae, which should be able to load directly.  On Google Earth 6.1, I have that option to load it directly.
BethNorton
I did that.  Could it be that I am not using Google Earth Pro?
