Negative Z values in ArcScene
1304
12-08-2012 05:37 AM
BeckyOswalt
I am trying to display earthquake depths in arcscene; however the points are appearing above the basemap instead of below. I used the field calculator to make the z values negative, but all the points are still above the land. How can I get them underneath the map?
Tags (1)
TimothyHales
Esri Notable Contributor
How are you setting up the base heights?  Are you using the option for elevations from features with the field as the expression?
About defining the z-value for a layer
You could also use Feature to 3D by Attribute to see if that feature class will display any differently.
