lod.slpk field missing attribute storage information?
1527
07-31-2020 12:20 PM
MadisonWilson
I have a mesh in a lod.slpk file that I exported from Pix4d that I want to open in ArcPro. I ran the Validate Scene Layer tool, and I received the following message in the output JSON file:
"Layer type" : "IntegratedMesh", "Messages" : ["Warning : Field 'ObjectID' is missing corresponding layer.attributeStorageInfo declaration"]
I've done some Googling but am unable to figure out what this means, and I no longer have access to Pix4d.
Thank you!
Andrew--Johnson
Hi Madison,
If you see a warning it's more informational rather than an issue that will affect display in an ArcGIS client. Errors are the ones to be concerned about as that could lead to display problems. Since attributes aren't yet supported in integrated mesh scene layers yet this is not a problem and is expected.
thanks,
Andrew
