Layer Properties Scene Crash
1077
02-23-2010 03:01 PM
TedCronin
If I right click on the attribute window and select Layer Properties.  CRASH.  See dmp file attached.
Scene does close out gracefully, though compared to Globe.
Tags (1)
TedCronin
Duped selecting a polygon, open attribute window, select feature in Attribute window, right click select Layer Properties - CRASH.
DeepinderDeol
Hi Ted,
I assume your post is about accessing Layer Properties by right clicking on a record in the attribute editor?
If yes then this is a known issue and should be fixed in the final release.
Thanks for testing,
Deepinder Deol
3D-Team
TedCronin
Hopefully, All my crashes will be fixed for Pre Release and definitely for final, so thank you for getting back to me and responding.
