Layer naming for Minor and Major Contours
3499
05-06-2013 05:01 AM
GregSullivan1
I created a shapefile of contours from a USGS DEM. I created a column in the attribute table called "layer" as a string so I can export to cad with the data on specific layers. I want all the 5 foot contours to be on the major contour layer and the rest to be on the minor contour layer. Does anyone have and help for how to do this?
Tags (1)
JeffreySwain
I would recommend the Contour with Barriers tool to specify the option to generate index contours.  This will add a field to the contour file.  Then you can actually see the fields with the different contours.
