Issue with TIN to Raster Conversion in ArcPy – Cannot Set Cell Size Below 1
1255
07-07-2025 01:20 AM
Luis761
Hi everyone,
I'm working with ArcPy and using the TIN to Raster tool in my current workflow. The raster cell size is a parameter that can be set via a GUI input. However, whenever I try to set the raster size to a value smaller than 1, I receive the following error:
ERROR 000323: The parameter value must be greater than 0.
Failed to execute (TinRaster).
Here’s the relevant code snippet:
# 4.2) TIN to raster
out_tif = os.path.join(workspace_raster, "raster_1")
arcpy.ddd.TinRaster(tin_raster, out_tif, "FLOAT", "LINEAR", "CELLSIZE", raster_size)
  • The code works as long as raster_size is greater than or equal to 1.
  • Setting a value below 1, either by passing the parameter or hardcoding it (e.g., raster_size = 0.5), always results in the error above.
  • Attempting to use the "CELLSIZE 0.5" syntax for sample_distance doesn’t resolve the issue either.
What's strange:
When I use the TIN to Raster tool directly in the ArcGIS Pro GUI, I can set cell sizes smaller than 1 with no problems on the same data.
Has anyone else experienced this?
Is there a workaround or a way to bypass this limitation in ArcPy, without having to resort to the manual tool in ArcGIS Pro?
Thanks in advance for any advice or ideas!
Kind regards, Luis
DanPatterson
MVP Esteemed Contributor
Have a look at specifying the z-factor and the last parameter explicitly
arcpy.ddd.TinRaster(in_tin, out_raster, {data_type}, {method}, {sample_distance}, {z_factor}, sample_value)
....  "FLOAT", "LINEAR", "CELLSIZE", 1.0, 0.5)
data_type  Float
method  linear
sample_distance cellsize      cellsize needs a value from the last parameter, the tool
z_factor  1.0   optional, but specify as a float
sample value    0.5   The cell size to use
... sort of retired...
Luis761
Hey thanks a lot for your answer. Unfortunately I get the same error with this approach..
DanPatterson
Tech support would be your best bet now
