Insert texture to an extruded polygon
803
07-19-2018 07:32 AM
Aneesha_Balakrishnan
I am trying to do a fence diagram (in arcscene). I am stuck when I am trying to insert lithologic patterns (textures) into the extruded polygon. I understand that Shapefile multipatches do not support textures. But is there any way I can convert the shapefile with multipatches to a regular 3D polygon. Bascially instead of solid colors I would like use textures in the extruded polygon. Right now when i am trying to insert the texture, it shows straight lines across the boreholes ( which is not right, I am trying to insert 24K GEOL ,607 pattern). I am attaching an image to give an idea where I am stuck and would appreciate if anyone can help me in this matter.
Thank you,
