Inport .skp into ArcGIS Pro
6380
04-08-2016 04:56 AM
changyao-shin
I'm the beginner of Arcgis pro.
Where is the code wrong ?
arcpy.env.workspace = "C:\Projecct\SketchUp"
arcpy.Import3DFiles_3d("geo.skp", "Test.gdb/AddisSheraton", 'ONE_FILE_ONE_FEATURE','' , 'Z_IS_UP', 'SKP' )
Runtime error
  File "<string>", line 2, in <module>
  File "c:\program files\arcgis\pro\Resources\arcpy\arcpy\ddd.py", line 1008, in Import3DFiles
    raise e
  File "c:\program files\arcgis\pro\Resources\arcpy\arcpy\ddd.py", line 1005, in Import3DFiles
    retval = convertArcObjectToPythonObject(gp.Import3DFiles_3d(*gp_fixargs((in_files, out_featureClass, root_per_feature, spatial_reference, y_is_up, file_suffix, in_featureClass, symbol_field), True)))
  File "c:\program files\arcgis\pro\Resources\arcpy\arcpy\geoprocessing\_base.py", line 500, in <lambda>
    return lambda *args: val(*gp_fixargs(args, True))
arcgisscripting.ExecuteError: ERROR 050038: No Valid Files
CreateFeatureClassName: The workspace Test.gdb does not exist.
Failed to execute (Import3DFiles).
DanPatterson_Retired
to remove the obvious
this .... "C:\Projecct\SketchUp"
should be this .... r"C:\Projecct\SketchUp"
or this .... "C:\\Projecct\\SketchUp"
or this .... "C:/Projecct/SketchUp"
since python requires raw notation or the use of forward slashes or double backslashes
changyao-shin
Dear Patterson
thanks for you help
but after compiled , I could saw the result but couldn't saw the shp I want on the screem.
How can I add the shp which I compile ?
that is a result object Result—Help | ArcGIS for Desktop
This tool just adds it to a multipatch Import 3D Files—Help | ArcGIS for Desktop do you then have to add it to manually? it is isn't clear, but you go no error message so either it worked or it worked but does nothing.
changyao-shin
It seen not the reason
I found it show add the "Symbol field"
But I cant understant what should I fill in this option.
