Increasing point size in colorized RGB LIDAR
972
04-30-2013 01:08 PM
BentonChing
With the LAS toolbar, I am able to change the point size using elevation, class, return, or intensity, but not RGB.  When I look at the data, it is sparse as compared to Microstation where you take the same points but make the dots larger.  Has anyone figured out a way to change the symbology for LAS files classified by RGB values?
Tags (1)
